Trouble with warm (HOT!) weather driving...
  • #16
    it should not.. the whistling noise is from the air box.
    Vinny
    - former SPYKER Employee, but a fan for life....
    • #17
      Read this topic again: http://www.spykerowner.com/forum/tec...ot-loaded.html
      And now I see that the two noises don't have anything to do with each other.
      The gearbox is changed for this reason?
      The second issue is that it makes a short squeal when you shift gears. This sounds a lot like a rapper scratching a record for about a tenth of a second. It is very distinct and it almost certainly metal on metal.
      • #18
        This is incorrect. The whistling is NOT from the airbox. The whistling sound i am experiences is most likely from the pinion gear within the gearbox.
        • #19
          I'm glad you found it. there is nothing more annoying than a whistling sound or a rattle you cannot fix. It gets under your skin
          • #20
            Finality to this issue guys. The change in gearbox got rid of the noise. Also, the new ECU settings are spectacular. Along with this I had Johan do a couple of other small things. I can now see the blinker light in the dash. Good stuff...
            • #21
              That is a huge improvement. I hated that the blinker and high beam lights were covered by the steering wheel. For me these issues got solved when I installed the propeller steering wheel.
