Go Back   Official Spyker Owner Forum > Spyker Enthusiasts - Public Forum > Technical Q&A
  #1
Old 17-07-2017, 02:25
kschuster kschuster is offline
Spyker Enthusiast
Spyker C8 Spyder Battery Question
Hi, I currently have a Interstate MTP91 battery in my Spyker C8 Spyder. I'm looking to replace the battery with a smaller battery or one of comparable size with more power. Does anyone have any recommendations? Thank you!
  #2
Old 17-07-2017, 17:09
Laviolette GT2R's Avatar
Laviolette GT2R Laviolette GT2R is offline
Spyker Enthusiast
Hi and welcome to the forum!
Not sure which brand battery the Spykers originally are equipped with but I think a Varta battery. Anyway, the specs should be: 75Ah/720A(EN), ETN 575121072 or equal, p/n 0061400010
Can you maybe tell which Spyker you have?
Winning on sunday, selling on monday!
  #3
Old 17-07-2017, 18:41
Spyker Owner #207 (former owner #107)
The MTP91 is the correct battery for US cars. It only needs a different clamp to secure the different foot. The Spyker is very sensitive to to the battery "fresness". Often small electric glitches go away with a new battery, even when the battery seems OK.
  #4
Old 31-07-2017, 20:37
AlexSpyker AlexSpyker is offline
Spyker Owner #151
The MTP 91 is no longer manufactured. Anyone has any other suggestion? The interstate suggested replacement one is half an inch too tall.
  #5
Old 27-08-2017, 13:36
mrobin33 mrobin33 is offline
Spyker Owner #138
Did you find a battery that works instead of the MTP91? My battery has failed (about 4 yrs old) so need to replace
  #6
Old 27-08-2017, 16:09
Working on that.
  #7
Old 27-08-2017, 18:21
Spyker Owner #138
Thanks - seen a few suggestions on other forums (fora?) - Porsche etc but need to check size will fit by taking the old one out and measuring the space; when I get a chance. In the meantime I can start it once if it's been on the charger for a while and make sure I don't stop again before getting home!
  #8
Old 01-09-2017, 16:27
Spyker Owner #138
Battery is out and so unable to drive car now! Having trouble finding a replacement small enough with the same spec. May have to compromise. Does the factory have an opinion? Needs to be max 275mmx175mmx175mm to fit nicely.
  #9
Old 06-09-2017, 12:19
Chris says that the replacement is the Interstate MTP-48(H6). The width and the length are the same as the MTP-91, but it is half an inch higher. I haven't been able to test if that works.
Matthew, since you have the battery out, can you check that?
  #10
Old 07-09-2017, 05:05
Spyker Owner #138
Work in progress. I got an H6 myself after researching all about BCI vs. DIN battery sizes and measuring the space every which way. By my calculation the higher H6 size (7.5" not 7") will just fit the space. HOWEVER - the problem is getting it in as it has to be angled forward, slid back and down into its place. There is no room for that manoevre without removing a couple of bolts that clamp the steering rack to the chassis. I did that and managed to squeeze it in so now the battery is sitting in its box but I am not completely happy it is level as it still touches the chassis frame. I will try some more fiddling before I put it all back together again, and report back.
If I am unhappy it does not sit right I will have to get a smaller size battery even though it has a lower capacity than recommended - not ideal either. Also note that the H6 is 5Kg heavier than the original MTP-91 too so I will need to diet or run with less fuel.
Picture shows one of the bolts you need to remove - one similar the other side.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
