Go Back   Official Spyker Owner Forum > Spyker Enthusiasts - Public Forum > Spyker Discussion
Old 31-12-2017, 21:11
Sandy Eggo Sandy Eggo is offline
Spyker Owner #153
Dash clock calibration
Has anyone else had the hour hand on their dashboard clock get out of calibration?
I know how to change the time...not talking about that. What I mean: for example, if I set the minutes at the top of the hour, the hour hand is not on the selected hour - it's usually about a quarter of an hour "off" in terms of where it's pointing.
How can I get the hour hand calibrated or re-zeroed if you will? Hope this makes sense, I can add a picture later if need be.
Old 02-01-2018, 00:50
Yes mine has that 'feature' as well. I thought mine must have been a special order option, but if you have it as well maybe it was standard fitment. If you find a way to fix it let me know!
Old 02-01-2018, 02:16
When I adjust the time, I have to turn the minute hand twice around to change one hour. Do you have that too?
Old 02-01-2018, 18:22
Jasperdd Jasperdd is offline
Spyker Owner #003 #008 #012 #013 #055 & #253
I have checked the Factory specifications of Siemens VDO and there is no possibility to calibrate the clock.
Old 03-01-2018, 05:48
Spyker Owner #153
Sounds like I have to just live with it - which is not the end of the world.
Now that you mention it, yes I do think mine behaves this way as well.
Thanks for the definitive answer (and the PM). I will learn to consider it a "feature" because replacing it sounds like eventually it ends up failing again.
