Go Back   Official Spyker Owner Forum > Spyker Enthusiasts - Public Forum > Unofficial Spyker Register
  #61
Old 15-09-2017, 02:02
Good advise. I have one corner loose too...
  #62
Old 15-09-2017, 20:41
Originally Posted by Scott Triplitt View Post
Hi Marrhew,
Perhaps reattaching with epoxy like the original would be best. There is an epoxy putty roll that can be purchased at the hardware store and it has a catalyst embedded in the center of it. Just cut pieces off the roll and work the putty until the catalyst is spread throughout the piece of putty. Then reapply the putty pieces to the studs and fender by pressing in place. Make sure the mesh is properly aligned, because once the putty is set, you won't be able to make any adjustments without ruining the mesh. I've done this before on another car and it held perfectly.
I would avoid anything where heat is necessary (like welding) because it would ruin the paint on the fender.
Thanks Scott. That's what I was thinking, though I was also wondering about a silicon product as it may be more flexible with the vibration, but not sure how it would last. If I could rivet in a straight line that would be my preferred approach!
  #63
Old 16-09-2017, 03:32
I don't think you need flexible silicon, since the mesh is not stiff by itself...
  #64
Old 16-09-2017, 16:36
... that are glued to the fender, then the liner bolts to the frame inside the fender...
According to Spyker they are indeed glued to the fender with a two bond glue. The brand used, is Hysol. The product number will follow on Monday (Rijk will get it from Spyker Cars).
Surface needs to be sanded and degreased otherwise it won't hold.
  #65
Old 22-09-2017, 13:10
From HarmJan at Spyker: https://www.google.nl/search?q=locti...obile&ie=UTF-8
  #66
Old 23-09-2017, 22:23
Thanks! Will see how I get on. Quite like the look without the grill at the moment - menacing!
  #67
Old 15-01-2018, 04:28
Stuck the grill back on with the two part epoxy. Seems good. Will put some soft padding in the wheel arch liner to hold it firm so it does not vibrate loose again...
File Type: jpeg 0845A932-0CE5-4B95-B210-18D7F97B016B.jpeg (1.45 MB, 11 views)
  #68
Old 28-01-2018, 01:41
A couple hundred miles today - great weather at last; dry, no salt and above 10C.
File Type: jpeg BE8BFADB-9DC5-4772-81B0-184B1E8FD705.jpeg (617.6 KB, 2 views)
File Type: jpeg 640B024F-8E0A-47A0-ABEA-40C108225FB3.jpeg (994.5 KB, 2 views)
  #69
Old 28-01-2018, 01:43
More...
File Type: jpeg F61E4721-63AE-4905-8248-FE939B00DE02.jpeg (524.0 KB, 2 views)
File Type: jpeg 9C921356-752F-4C11-BCDC-92A354B0C661.jpeg (972.1 KB, 2 views)
  #70
Old 28-01-2018, 01:49
8000 miles of fuel data.
File Type: jpeg 58F50088-A0B2-418C-B37D-D0601A71DB1A.jpeg (131.8 KB, 6 views)
File Type: jpeg A26BB463-20D0-496C-9169-3FFCB490F88A.jpeg (136.9 KB, 4 views)
