Go Back   Official Spyker Owner Forum > Spyker Enthusiasts - Public Forum > Racing & Tracking
Old 05-05-2008, 19:25
AX lover AX lover is offline
C8 Laviolette GT2R - 2008 Specs
2008 Spyker C8 Laviolette GT2R specifications
Engine
- Make: Audi
- Type: V8 90 degree block angle
- Capacity: 4000 cc
- Power: approximate 445 bhp (but depends on restrictor size)
- Torque: 442 Nm
- Maximum revolutions: 8700 rpm
- Pistons: Mahle
- Valve train: Del West
- Conrods: Pankl
Transmission
- Rear wheel drive
- Hewland NLT 6 Speed Sequential gearbox
- AP-Racing carbon clutch
Chassis and suspension
- Aluminium space frame with integrated roll cage
- ATL Safety fuel tank of 90 liter capacity
- Fully adjustable independent suspension
- Moton coil over damper Adjustable shock absorbers with Eibach springs
- CNC machined Upright from solid billets of aluminium
Electrical system
- Bosch MS 4.2 engine management system
- Pi Sigma Data logging system
- Pit to Car radio communication system
- Tyre pressure warning system
- Electrical power steering
- Xenon Lights
- Race application wiring harness
Brake system
- AP-Racing.
- Twin-circuit brake-system with adjustable brake balance, 6-piston aluminium brake calipers at the front and rear with ventilated grooved brake discs
- Brake disc diameter, front 355 x 32 mm and rear, 378 x 35.5 mm
Wheels and tyres
- OZ racing wheels with central locknuts
- Tyres Michelin, Front 260-670/18, Rear 270/710/18
Sizes and weights
- Kerb weight: 1125 kg
- Wheelbase: 2580 mm
- Overall length: 4177 mm
- Fuel tank capacity: 90 Ltr
- Minimum ground clearance: 50 mm
Old 05-05-2008, 19:30
And for comparison the 2007 C8 Spyder GT2R specs.
Spyker C8 Spyder GT2R (2007 specs)
Bodywork
- All aluminium lightweight body with adjustable rear wing.
Engine
- Make: Audi
- Type: V8 - 90 degree block angle
- Capacity: 3800 cc
- Power: 465 BHP
- Torque: 442 Nm
- Pistons: Mahle
- Camshafts: Del West
- Valves: Del West
- Conrods: Pankl
Transmission
-Rear wheel drive
-Hewland NLT 6 Speed Sequential gearbox
- AP- Racing carbon clutch
- ATL safety fuel tank of 100 liter capacity
- Koni coil over damper Adjustable shock absorbers with Eibach springs
- CNC machined uprights from solid billets of aluminium
Electrical system
- Bosch 4.2 engine management system
- MRTC Pit to Car radio communication system
- Electric power steering
- Philips Xenon Lights
Brake system
- AP-Racing
- Twin-circuit brake-system with adjustable brake balance, 6-piston aluminium brake callipers at the front and rear with ventilated grooved brake discs
Wheels and tires
- Wheels: OZ-racing
- Tires: Dunlop (Le Mans Series) / Michelin (Le Mans)
Sizes and weights
- Kerb Weight: 1125 kg
- Wheelbase: 2585 mm
- Fuel tank capacity: 90 litre
Old 05-05-2008, 19:55
Hmm 20 bhp LESS for the new 4 liter engine? Or do they say that to throw Porsche and Ferrari sand in the eyes
Old 05-05-2008, 20:22
Found the power of the Porsche 997 GT3 RSR
max. output: 342 kW (465 bhp) at 8000 rpm
max. torque 430 Nm (317 lb-ft) at 7250 rpm
air restrictors 2 x 29.5 mm
max. rpm: 9,400 rpm
Can't find anything about the Ferrari F430 GT though...
Old 09-05-2008, 13:05
A new sound emerges from the Spyker pit box
By Marcel ten Caat
As the final preparations ahead of the first free practice session of the weekend for the Le Mans Series where underway at Spa-Francorchamps, there was an interesting sound coming from the pit box where both Spyker C8 Laviolette GT2R cars are this weekend. Instead of the usual deep rumble from the engines a complete different sound emerged from the back of one of the cars.
When the cars left the pit lane on their first lap around the Belgian circuit it became clear that the long awaited new engine had been installed by the Dutch squad in the number 85 SNORAS Spyker Squadron Spyker C8 Laviolette GT2R and the Spa-Francorchamps round will be the first race for the engine before the team heads to Le Mans for the annual 24 Hours of Le Mans.
The impact of the new engine will probably not be known after this session, as it is only the first test. More about this development later…
We hope to have a comparison of both the new and the ‘old’ Spyker engine online soon, as the number 94 Speedy Racing entry is still fitted with the old engine.
Source: Planetlemans.com, May 9, 2008
Old 09-05-2008, 18:07
Reddingius's Avatar
Reddingius Reddingius is offline
Send a message via MSN to Reddingius
This makes me very curious. It is still a V8, it has more cubic inches, a slightly lower power output.. This leads one to suspect a more American-ish sound.
The article above however doesn't describe the new sound but it does say it differs from the old, low rumbling noise. From this I for one conclude that the new sound aught to be higher in pitch than the old. How can this be given the fact that the engine is larger and slightly more lazy?
Very interesting...
Old 09-05-2008, 18:34
Laviolette GT2R's Avatar
Laviolette GT2R Laviolette GT2R is offline
The article on Planet Le Mans is probably up-dated:
Peter Dumbreck did the shakedown today. One of his points of focus was to find what the best time to change the gears is with the new engine. The new engine also means the Spyker C8 Laviolette GT2R has more power and more torque, which resulted in the car already being quicker than the number 94. The new engine has a completely new lay-out and a new crankshaft.
For now the team will keep testing as several components will have to be optimized for the new engine.
Source: Planet Le Mans - Marcel ten Caat
Very interesting...
Now that we know it has a higher power output, the higher pitched sound makes more sense .
Winning on sunday, selling on monday!
Old 09-05-2008, 19:25
Reddingius's Avatar
Why is the new engine larger? If the engines were allowed to be larger last year, they would have driven with an engine as big as the regulations would allow right? So have the rules changed and if so, why? They also mention that the new engine has an all-new layout. What is meant by this? It is still an Audi v8 in essence, so what is new about it in terms of layout?
I hope the engine is a revver! more cubic inches plus more revs equals a great piece of kit!
Old 09-05-2008, 20:54
The engine is larger because they needed more horse power to get a better topspeed. There is a formula between engine displacement, air-intake-restrictors and total car weight. In short: A bigger engine gets a smaller air-intake-restrictor or / and a higher minimal total car weight. So it's not necessarily better to enlarge the engine to the maximum capacity allowed. In long: http://www.lemans.org/sport/sport/re...fr_gb_2008.pdf (appendix 1 page 23)
Also read Article 5 (page 9 onwards) for more rules concerning the motor, from this article I learned that the basic things of the race motor must be the same as the production motor. Unless Spyker got some dispensation, it's not very likely that the layout is entirely new...
I hope this helps!
