Go Back   Official Spyker Owner Forum > Spyker Enthusiasts - Public Forum > Unofficial Spyker Register
  #51
Old 21-01-2017, 22:50
And more...
  #52
Old 21-01-2017, 23:30
Looking very good.
  #53
Old 22-01-2017, 05:03
Looking great
  #54
Old 22-01-2017, 06:52
Wouter's Avatar
Wouter Wouter is offline
looks nice but stil a bit cold?
  #55
Old 23-05-2017, 18:04
Here's the sticker.... inaccurate as it didn't have dunlop tires nor the aeroblade steering wheel to begin with... soft top seems good value compared to the other options.
  #56
Old 23-05-2017, 20:50
Da man!
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
  #57
Old 23-05-2017, 21:54
Gosh I must be cool! Where did you find that?
  #58
Old 13-09-2017, 20:45
Loose Fender Grill
I noticed the mesh in one of the front fenders was lower than the other side - like it had become unattached; so I removed the wheel arch liner and found it had become unattached from the metal fender.
Seems the mesh is bolted to studs that are glued to the fender, then the liner bolts to the frame inside the fender. The glued bolts have all detached. Seems a strange way to do it - why not attach the mesh to the liner.
  #59
Old 13-09-2017, 20:47
Loose Fender Grill
Not sure whether to try to glue again, or try to attach to the liner... any ideas?
  #60
Old 14-09-2017, 20:18
Scott Triplitt's Avatar
Scott Triplitt Scott Triplitt is offline
Spyker Owner #228
Originally Posted by mrobin33 View Post
Attachment 17489
Attachment 17490
Hi Marrhew,
Perhaps reattaching with epoxy like the original would be best. There is an epoxy putty roll that can be purchased at the hardware store and it has a catalyst embedded in the center of it. Just cut pieces off the roll and work the putty until the catalyst is spread throughout the piece of putty. Then reapply the putty pieces to the studs and fender by pressing in place. Make sure the mesh is properly aligned, because once the putty is set, you won't be able to make any adjustments without ruining the mesh. I've done this before on another car and it held perfectly.
I would avoid anything where heat is necessary (like welding) because it would ruin the paint on the fender.
Scott
